No Oil Pressure Need Help Fast
Hey guys, this morning i went to start my car and it had no oil pressure. I was driving it around last night and it was fine, the only thing i heard was when i first started her up she made a whinning noise for a little bit but then went away. Is there a way i can check the oil pressure or see if its getting any oil. Im hoping its the pressure gauge switch and not the pump. Thanx for any input.
You can remove a valve cover to check if you are getting oil pressure, but thats not exactly clean nor fast.
I just finished taking off the intake manifold and got the sensor out. I pulled the fuel pump and ignition realys and cranked the motor and dont see any oil coming out of the hole where the sensor screws in. would oil come out of that hole? Im praying its just the oil switch and not the oil pump because right now this is my only car.
