steering wheel has some slack how can i tighten it up??
Ok i doubt that the title specified much so here it is... well while im driving my car maybe 55mph, i can turn the wheel just a lil bit and the car will not react. like i can move my hands back and forth maybe 30 degrees both ways and the car will not react how can i get this slack out of it?? oh and i did take the steering linkange when i did the header install but i had to, so if you guys know something i can do to help this i would greatly appreciate it.
thanks'
B.J.
thanks'
B.J.
Most likely the coupler is not tight enough where the steering linkage attaches to the rack. Same problem on mine...I completely removed the bolt that holds the linkage on, shook it around a little to make sure the spline engaged. Red loctited the bolt and tightened the holy hell out of it. Problem went away.
