Sponsored by: CARiD
Blinker not working
Old Oct 2, 2006 | 07:37 PM
cptncdy's Avatar
Default Blinker not working
K well the bulbs are fine all the way around, but on the passenger side when you use the turn signal it stays lit- no blinking. I went to Napa and a guy said it was a flasher relay(small cylinder). So I bought it and tried to install it, but I have no idea where it goes. I took off the panel under the steering wheel but no luck. 1. Is that the right solution for the blinker?
2. Where's the relay?
Thanks
Old Oct 2, 2006 | 07:56 PM
GM Muscle's Avatar
Here's a pic. If you bought the oversized HD flasher from Napa (like the one pictured), don't reuse the factory clip, just let it hang. If you use the clip on the bigger HD unit, it will compress the casing and it will stop working.
Old Oct 2, 2006 | 08:28 PM
cptncdy's Avatar
Thank you!! Since the one I bought was a clear cylinder, I totally missed the factory flasher! I'll get it done in the morning and let you know how it goes.
Old Oct 3, 2006 | 01:13 PM
bjamick's Avatar
also this may be a fuse.. check into that. if its for sure not a bulb.
Old Oct 3, 2006 | 02:33 PM
spy2520's Avatar
could always be your blinker fluid...
Old Oct 3, 2006 | 07:55 PM
theblur98ss's Avatar
I had a bad ground on mine also causing problems.
Old Oct 3, 2006 | 08:20 PM
itsmike's Avatar
i have the same problem.
any idea where the bad ground may be? i recently had my bumper replaced and now the driver side bliinder isnt working. i gotta take it back to the shop, but does anyone know whats up with it? how can i know if the flasher relay needs to be replaced?
Old Oct 3, 2006 | 08:53 PM
cptncdy's Avatar
i wish i would have known where to look yesterday. when i went to change it out today it only took me about 5 minutes. now my blinkers work as good as new. thanks!
Old Oct 3, 2006 | 10:05 PM
GM Muscle's Avatar
Cool, glad it was an easy fix.
