Sponsored by: CARiD
Car won't start!
Old Oct 4, 2006 | 04:06 PM
Demian's Avatar
Default Car won't start!
Car just clicks when I turn the igniton.
Troubleshooting advice?
It never had a issue starting before.
Old Oct 4, 2006 | 04:07 PM
LT1-DAN's Avatar
check the battery or starter?
Old Oct 4, 2006 | 04:10 PM
LT1-DAN's Avatar
check the battery terminals make sure they are tight and clean.
Old Oct 4, 2006 | 04:17 PM
2001NBMZ28's Avatar
Go for the battery/connections first. If you have a digital volt meter see what it's reading. Sometimes the make a rapid clicking, one click and die, or just die and won't click at all.
Old Oct 4, 2006 | 04:34 PM
notatruews6's Avatar
Has Unresolved Sales In Feedback/12 second club
Sounds like a dead battery to me, whats the voltage shown on the volts gauge? if its way down in the red the battry is dead... try jump starting it.
Old Oct 6, 2006 | 05:26 PM
Demian's Avatar
Battery is fine....I should have stated that earlier...It has a charge but the car just clicks.
Old Oct 6, 2006 | 05:30 PM
flyinglow57's Avatar
one solid click. its prob a starter.. if a manual.. try drift starting. also. turn your interior lights on. try to start. if your lights dim exesively then its proba battery.. if they are fine. (light turns off when you turn key but ocmes back jsut as bright when you let off no dimming just on/off) then its probably a battery.
check to make sure your terminals are clean. alot of time currosion builds up under the red/black parts on the side mount terminals and cause it not to start.
good luck if you have any questions pm me. i work for AAA and see this about 14 times a day over the past 2.5 years. so i kinda know alot of the tricks.
Old Oct 7, 2006 | 10:45 AM
Demian's Avatar
Thanks Brother!
Old Oct 13, 2006 | 09:12 PM
Originally Posted by Demian
Thanks Brother!
any update?
