Sponsored by: CARiD
Still have a shaking problem
Old Oct 4, 2006 | 05:27 PM
MarkSTL's Avatar
Default Still have a shaking problem
I had my tires spin balanced and rotated, my brakes pads are new, I have brand new drilled and slotted rotors. The front end was aligned a day or two ago and for some reason my 01 TA still shakes under braking and acceleration. I have no clue what the hell this could possibly be.
Old Oct 5, 2006 | 12:14 AM
RoadHazard's Avatar
Your outter tie rod ends may be on the way out.
Old Oct 5, 2006 | 06:40 AM
Charging TA's Avatar
Have you checked the rear end bushings? Could also be front end bushings...
Old Oct 7, 2006 | 11:23 AM
1badragtop's Avatar
Since it happens under braking and accelerating, I would check the u-joints for sure and then look at all the suspension bushings.
Old Oct 7, 2006 | 11:46 AM
staringback05's Avatar
as stated before check all of your bushings.....esp. the control arms and your tie rod
Old Oct 7, 2006 | 09:57 PM
trackbird's Avatar
If the alignment is considerably out of spec, you could be picking up a vibration there.
Old Oct 8, 2006 | 07:38 AM
shaun's Avatar
my car has the same problem. every thing is perfect on it and it still vibrates. it could be from your tires.
Old Oct 9, 2006 | 04:37 PM
MarkSTL's Avatar
If the tie rod and control arms are bad would that cause a floating feel to the car, when turning.
Old Oct 9, 2006 | 06:01 PM
30th droptop's Avatar
It sounds like something is loose in the suspension or steering. I guess it could also be the driveshaft, as has been said, but not as likely.
Get it up in the air. If all you've got is jackstands, put the front end up first, since that's the most likely problem area. Try to pull out on the top and bottom of each wheel, as well as move it side to side (steering motion). Also try to move the wheel up and down. Watch the suspension components and steering rack/tie-rods for movement. Movement that leads to vibration is usually pretty obvious.
Old Oct 9, 2006 | 06:03 PM
trackbird's Avatar
Define turning. Turning into a parking spot? Or, turning onto an exit ramp at high speeds? At low speeds it could cause the steering to be vague and the car might wander around or feel sloppy. Floating at high speeds is usually related to the shocks (not enough rebound damping), but worn tie rod ends can make the car wander and feel very vague.
