Sponsored by: CARiD
Power steering fluid
Old Oct 4, 2006 | 08:06 PM
oifish's Avatar
Default Power steering fluid
I need to add a little bit of power steering fluid to my reservoir and i just have a simple question, search came up with nothing so thats why Im asking.
Im just wondering if there are any different types of fluids or is it pretty much universal?
Thanks in advance
Old Oct 4, 2006 | 10:15 PM
staringback05's Avatar
ps fluid is kinda like oil you need check on the different types...
Old Oct 5, 2006 | 12:36 PM
oifish's Avatar
I went to autozone and they said its the same for most cars except for Honda. I also read in the owners manual and I diddnt see anything that said it needed any specific type.
Old Oct 8, 2006 | 08:54 PM
2001FireBird's Avatar
I went to my auto store too and they said Honda was the only one that use specific fluids. I bought Valvoline Power Steering fluid, and just added it in. The guy also said I could use the stores brand but I got the valvoline for piece of mind.
Old Oct 8, 2006 | 09:34 PM
Da Swami's Avatar
Yup.
You can get some with stop leak in it if you have a slight leak, but otherwise it's just brand loyalty.
I think Valvoline makes a high mileage version.
Old Oct 9, 2006 | 04:16 AM
Charging TA's Avatar
Supposedly you can also use ATF as PS fluid.
Old Oct 9, 2006 | 08:17 AM
quiksilver9531's Avatar
you can.
Old Oct 9, 2006 | 03:45 PM
01WS6er's Avatar
I have always used ATF in my gm porducts pwr str system. I exchange it about every 2 years to keep it clean.
Old Jan 8, 2007 | 11:49 AM
WS6 John's Avatar
Any issues with using synthetic ATF for the PS?
I want to fix a small leak and flush mine. I am not sure if using a synthetic ATF is Ok versus just regular ATF in the power steering.
Old Jan 8, 2007 | 03:22 PM
dailydriver's Avatar
I've had either Redline or Royal Purple p.s. fluid in there for the last 6 years. I think it has actually helped the pump live to the ripe old age of 7 years/100K miles!! I use the "turkey baster method" of changing it every year-year and a half.
Old Jan 8, 2007 | 04:42 PM
kezy219's Avatar
thats all ford uses is atf for all their cars....
Old Jan 21, 2007 | 10:00 AM
jman0322's Avatar
not to mention ATF is a lot cheaper and I've been using it for years especially if you have a slow leak. fyi
Old Jan 21, 2007 | 11:44 AM
tbarnard2's Avatar
Default power steering fluid
Gm using power steering fluid
Ford, Mazda, BMW, VM, Mercedes, Volvo uses ATF
Honda and Acura uses a make specific fluid
Old Jan 21, 2007 | 08:35 PM
zspot98's Avatar
You can use ATF in GM cars. I've done it in my 93 1500, (171,xxx) and 98 Z with no problems, ever.
Old Jan 21, 2007 | 08:46 PM
brad8266's Avatar
yeah its recommended in my ford taurus. I used PS fluid and it was noisy, replaced it with ATF and it is now quite again.
Old Feb 18, 2007 | 06:53 AM
2edybrd's Avatar
OK, I'm glad I found this thread. My power steering popped a hose last night and emptied my steering fluid all over the parking lot.
It's an easy fix, but I was very concerned about the fluid I can use as the dealerships aren't open on SUnday.
So, ATF is fine to use. Just the regular stuff, or is synthetic ok?
