Sponsored by: CARiD
Hatch doesn't always open first time i hit the button?
Old Oct 11, 2006 | 01:47 PM
bjamick's Avatar
Default Hatch doesn't always open first time i hit the button?
Well when i first get into my car and i hit the hatch button it pops it but when i get out to try to open it it wont open all the way. So i hit the button again and then finally it will open. This is like everytime so what can i do is there something wrond with a vacuum line or something?
please help me.
Old Oct 11, 2006 | 01:48 PM
CASHss99's Avatar
put a stronger spring in
Old Oct 11, 2006 | 01:50 PM
CASHss99's Avatar
http://www.installuniversity.com/ins...sity/index.htm
go to install documents. look for it in there
Old Oct 11, 2006 | 01:59 PM
Dimitri-'s Avatar
Or you can just press it twice really quick...
Old Oct 11, 2006 | 03:02 PM
Arctic2002ss's Avatar
Just go down to your local hardware store and buy a C-141 spring. It's 5/8" X 1-1/2". Pull back the lining around the latch and piggy-back this spring onto the factory one. You will probably have to tweak the hook on the spring a little to get it on there. Fixed!
edit: This works on an '02 Camaro. I think the 'bird is the same.
Old Oct 11, 2006 | 03:40 PM
bjamick's Avatar
Heck ya man i forgot all bout install university i appreciate it man that should def. fix my problem. thanks alot. i def have to get this done.
Old Oct 11, 2006 | 05:01 PM
CASHss99's Avatar
yea cool
Old Oct 11, 2006 | 08:50 PM
BigDaddyBry's Avatar
Your choice is either (like Dimitri said) two quick pushes of the button vs. a hatch that has a recoil a shotgun would be proud of.
I opted for the extra pushes because I figured if the latch ever gave way due to the extra pressure of the spring (over time), the cost would be more than the benefit.
Old Oct 12, 2006 | 08:35 AM
dbuie's Avatar
The stronger spring fixed mine. It was aggravating for sure.
