Sponsored by: CARiD
Map sensor
Old Oct 18, 2006 | 07:42 PM
bubba24's Avatar
Default Map sensor
Okay I tested my map sensor LT1.
With igintion on but not started 4.5 volts roughly.
engine started at most even at warm temp 1.1 volts.
If I raise the throttle it actually lowers and goes to like .7 volts .8 volts. Now isnt it suppose to raise in volts when i raise the throttle?
So saying this map is screwed would that cause a idle issue idling rough?
Thanks
Old Oct 18, 2006 | 09:30 PM
staringback05's Avatar
do you mean maf sensor?
Old Oct 19, 2006 | 02:27 AM
bubba24's Avatar
nope the map sensor on the intake passenger side just behind the throttle body. Its a 95 lt1.
Old Dec 7, 2006 | 08:51 PM
bubba24's Avatar
okay I bought a map sensor and it still does not work. If I give the gas a quick shot the volts will rise, but If I slowly raise the throttle the volts slowly rise and if I hold it steady the volts stay low steadily. So how does that work?? Something has to be screwed
also in datamaster as I slowly bring up the rpm the kpa drops, only when I quickly snap the gas the kpa rises.
any help would nice
Old Dec 7, 2006 | 08:57 PM
check the load on the map wires....see your getting a good read from them
