Getting More Miles Out of Your Car
Getting More Miles Out of Your Car:
The following are some tips that will help you to get more miles out of your vehicle.
First, consider, does your vehicle actually have the ability to run many miles without incurring costly repairs? Find out by visiting a public library to consult the frequency-of-repair information in the April magazine issue of Consumer Reports. If your vehicle has a poor repair history, consider buying a vehicle that has better ratings and fuel efficiency.
If you want to extend the life of your vehicle, at the beginning of each month, have the engine oil level checked to make certain that it is at the full-level mark on the dipstick. Buying two quarts of oil that are on sale and keeping it in the trunk, will enable you to avoid getting stuck paying three times what the oil should cost. Be certain to only use the type of oil and other fluids as specified in the vehicle owner's manual.
Tire Pressure and Fluids:
Every three months (more often, however, if specified by your vehicle owner's manual) and prior to leaving for and upon returning from a trip, check (or have a service station attendant check) the tire pressure and the other fluids that include:
Transmission fluid
Brake fluid
Power steering fluid
Radiator coolant (check the clear plastic bottle)
Windshield washer fluid
Why is it important to keep the fluids at their full-level marks? The fluids lubricate moving parts to reduce fiction, heat, and wear. Therefore, they are the single most important factor for extending the life of a vehicle.
Engine Oil and Oil Filter:
If you drive 6,000 miles or less per year, have the engine oil and oil filter changed at the beginning of spring and near the end of fall. If you drive 10,000 or more miles per year, have the engine oil and oil filter changed every 3,000 to 3,500 miles or about every four months. An easy way to remember oil changes is to mark a new calendar at the beginning of a year with "oil change" reminders (i.e., May and November or April, July, and October).
Service stations usually run specials on oil changes (i.e., $10.99 - $13.99). However, make certain that the station is reputable. Some stations have been known to skip changing the oil or to do part of the job by changing the oil but not the oil filter. To help make certain that the oil filter was in fact replaced, use a black marker to put an X on the new oil filter after an oil change. When the next oil change has been completed, the newly installed filter should not include an X.
Check the Anti-freeze:
Prior to winter, have a service station attendant check the antifreeze in the clear plastic coolant bottle with a hydrometer (a device that takes a sample of antifreeze and specifies how cold the temperature can become before the antifreeze freezes). The antifreeze should be able to withstand (i.e., not freeze) temperatures of at least 30 degrees "below the coldest" winter temperature. If the antifreeze is too weak, have additional antifreeze added to the coolant bottle.
Purchase the type of antifreeze as specified in the vehicle owner's manual (i.e., usually a type that is suitable for "aluminum and all types of metals" that are used today's engines). It important to avoid frozen antifreeze because it can crack an engine's block which could result in possibly thousands of dollars for the repair.
Air Filter:
If you drive about 6,000 miles or less per year, have the engine air filter changed once every two years. If you drive over 10,000 miles per year, have the engine air filter changed once a year in the spring. Many discount stores regularly have sales on air filters.
Washing and Cleaning:
In the spring and in the fall give the vehicle a thorough wash, tar removal, and wax. When washing the vehicle in-between the seasonal waxes, use a car wash product that is safe for clear coat and waxed finishes.
Transmission fluid
Brake fluid
Air Filter:
