Sponsored by: CARiD
Changed Coilpack Brackets=NO START
Old Oct 20, 2006 | 09:52 PM
98REDZ's Avatar
Default Changed Coilpack Brackets=NO START
So i had my coil packs rigged on since i had no brackets, ...finally got around to putting the brackets on today so i took off the CP's and put them on the brackets and put them back on and plugged the wires back up accordingly and the harness back in,..accidentally i touched my ratchet from the pos. to the neg. side on the battery posts & it made a spark if that makes any different of WHY IT WONT START!??!?!?! SOMEONE PLEASE HELP. THANKS!
Old Oct 21, 2006 | 01:47 AM
Da Swami's Avatar
When you "touched [your] ratchet from the pos. to the neg. side on the battery posts & it made a spark," were both the terminals connected?
Also, what does the car do when you turn the key? Click? Crank? Nothing whatsoever?
Old Oct 21, 2006 | 02:00 AM
NoGamesLS1's Avatar
There is a fuse for each bank (left side and right side) of coils and injectors. The fuses are labled inj1 and inj2. Check those to make sure they are not blown.
Old Oct 21, 2006 | 10:45 AM
98REDZ's Avatar
Da Swami,..yes everything was plugged in...terminals included. And yes the car cranks over just fine and acts like i dont have the coil pack harness plugged in...but thats obviously not the case.
And NoGamesLS1 i've checked all fuses, they all look just fine.
Old Oct 21, 2006 | 01:40 PM
NoGamesLS1's Avatar
Do you have any other coil packs? When I got my car tuned by a certian somebody I had them put on msd coil packs and for some reason they ground down parts of my bracket and hit a wire. The wire was arcing on the valve cover and it burt out one or two of my coil packs. So if you've tried everything and still cant get it to work try that out. Small shot but I cant think of anything else right now
Old Oct 21, 2006 | 04:06 PM
98REDZ's Avatar
Yeah, the intake is snorting air real hard about once every rotation or so too for some reason. This is killin me
Old Oct 21, 2006 | 05:23 PM
98REDZ's Avatar
ok,....Can anyone tell me where the #1 & #8 cylinders are? I believe up front correct? The coilpacks are labeled and i had switched them around a few times but now lined the #1/8 end up on the front sides. Should be correct right?
Old Oct 21, 2006 | 06:24 PM
Shallow Bay's Avatar
The number one cylinder is located on the driver side, closest to the radiator. The number eight cylinder is located on the passenger side, closest to the firewall.
