Loud Squealing when turning...
Also the steering definetly is easier then my old one but to me there seems to be too much play in it. When you go over a slight bump it pulls the steering. This could be all normal but just asking.
Any ideas on what on earth this squealing could be????
Update.....just took out the car again and I'm leaning now more towards it having something to do with the tires. I was coming up to a light going perfectly straight and the light turned yellow so I had the hit the brakes kinda hard. As I did that the squealing noise came and stopped once I came almost to the stop. It was a very low squeal. I turned into a community and did some slight turns and sharp turns hardly moving at all and no squeals...just the whine now from my pump because the reservior is low at this point. I got back on the main road and by the time I get up to 50mph I hear the noise again...faint squeal. I checked the air pressure in all tires and all are about 35 psi. Tires are not worn and didnt make this noise until we installed the rack yesterday so I'm baffled
Thanks for the reply. What we did before the noises started was take out my old leaking rack and replaced it. We checked the serpentine belt and it seems fine but I'm going to replace it anyway. They guy I bought the rack from suggested that it is glazed like what you're saying. I believe you are right on the tires not hitting the road correctly and thats what my boyfriend diagnosed it probably being last night when I was able to let him hear the noises. We think we have two things going on with it. The tires not being right and it needing alignment as its definetely pulling to the right and that the rack is not getting enough fluid to it from the leak.
I'm going to get a new pressure hose and return hose along with a new belt. If the new hoses don't fix the leak then I'm at a loss
Its the only things left that werent replaced.Thanks again for the insight and help...muchly appreciated.
. Now I just have to find a good shop
