Sponsored by: CARiD
Temperature Guage Crazy
Old Oct 22, 2006 | 08:25 PM
chrizo28's Avatar
Default Temperature Guage Crazy
I have a 2000 z28 automatic....the car has 80,000 miles on it but runs great. Recently the temperature gauge has been shooting up to the red zone for bried periods (5 sec) then it comes back down to normal 210. It happens randomly and I cant figure out why. I think it may also be causing my power steering fluid to come out of the top of the lid. Any ideas of what the problem may be?
Old Oct 22, 2006 | 08:35 PM
Tainted's Avatar
wow lol. 2000 cars had a dummy temp guage and only shows an voerheating condition. are you sure the car isnt actually voerheating?
Old Oct 22, 2006 | 09:53 PM
CW00BlackTA's Avatar
Say what--where did you get that? Mine works like it should.
Your sending unit might be on the way out.
Old Oct 23, 2006 | 11:40 AM
2001NBMZ28's Avatar
The '99 and up gauge just doesn't reflect the actual temp - once warmed up shows more of a "range". If you're not overheating check the ECT sensor, connector and wiring by the #1 plug in the head.
Old Oct 23, 2006 | 07:32 PM
chrizo28's Avatar
Im not sure if it is really overheating, if it was why would it only overheat for 5 seconds? The guage goes all the way up until the check engine light goes on, the engine fan turns on, then 5 seconds later the temp goes back to 210. Unless told otherwise I am gonna change the temperature sensor hopefully that will do the trick
Old Oct 23, 2006 | 09:06 PM
Tainted's Avatar
try it. but 99+ cars have a dummy guage. if its showing an voerheat condition you may wanna watch out because it is possible
Old Oct 24, 2006 | 01:18 AM
staringback05's Avatar
its the gauge.....your car will not over heat for 5 seconds and then cool down...
Old Oct 24, 2006 | 09:02 AM
Weezzer's Avatar
Being a 2000 model, your gauge is a dummy and will read 210 as long as the actual temperature is between 180 and 226, when the temperature rises above 226 then your dummy gauge will read higher than the 210 reading.
Old Oct 24, 2006 | 04:36 PM
01WS6/tamu's Avatar
Check the instrument cluster data with a tech 2. temp gauge actual vs desired.
Old Oct 26, 2006 | 12:22 AM
SSatan's Avatar
Change your thermostat. just feel the hose after the thermostat housing.
