Sponsored by: CARiD
My solution to turn signal problem
Old Oct 23, 2006 | 04:07 PM
DVS99TRANS's Avatar
Default My solution to turn signal problem
I know most people know about this, but for those that don't. I drilled 3 holes into the bottom of each of the light assembly so water doesn't get caught in them and have not had a bulb problem since. I have replaced both sockets for the bulbs and it still didn't do alot until I drilled out them out. It's been about 3 months and still no problems. Hope it helps out.
Old Oct 23, 2006 | 04:26 PM
Danny2tek's Avatar
Yep I just changed out both sockets, and went to drill some holes but I realized I need a longer bit to reach the lamp housing.
Old Oct 23, 2006 | 04:50 PM
DVS99TRANS's Avatar
I just took mine out of the car, then drilled them. Cleaned em at the same time, the interior of the housing was real nasty. They're only held inplace with 2 bolts at the back of it (7mm if I remember).
Old Oct 23, 2006 | 04:55 PM
Danny2tek's Avatar
I'll give it a shot tommorrow
Old Oct 23, 2006 | 05:10 PM
DVS99TRANS's Avatar
It's best to go from underneath though the openings under the lamps. The AIR pump gets in the way on the driver side and caused alot of harsh language when I took them out.
Old Oct 23, 2006 | 05:15 PM
Danny2tek's Avatar
What AIR pump
Old Oct 23, 2006 | 06:58 PM
DVS99TRANS's Avatar
Now that's what I'm talking about.
