Sponsored by: CARiD
A little problem..
Old Oct 26, 2006 | 12:09 PM
the_merv's Avatar
Veteran: Air Force
Default A little problem..
This is what I got. The Engine along with everything else is in the car, and functioning.
This is the problem. I go to start it, it back fires, sputters, won't barely even fire, and it floods.
This is what I did to check it over..
Everyone kept saying timing, so I took it all the way down to the OPTI, and turned the Crank until the Cam went to 9:00 position, which was #1 TDC, and placed the OPTI correctly on it(only 1 hole for it). The Timing Chain went on correctly(dots touching), so now there is no way the timing is messed up.
Then I re-set the lash on the Rockers since they now have oil in the Lifters, so that is good.
I checked all the plug wires, and they are in the correct spots. Fuel Injectors are in the right spot.
The Starter works very well, no problems there.
It fires a couple of Cylinders, dies, fires a couple more, and it's done. That's with my foot to the floor. I think it's flooded, so I have to check that out.
I think it may be a Sensor somewhere, everything mechanical checks good, but if anyone has any input, throw it in..
Old Oct 26, 2006 | 07:14 PM
the_merv's Avatar
Veteran: Air Force
So nobody knows **** here....
Old Oct 26, 2006 | 07:28 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by the_merv
down to the OPTI.
Found your problem!
Old Oct 26, 2006 | 07:32 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Seriously though. I am going to move this to the maintenance section and see if anyone knows down there. Let me know if you want to try it in a different thread.
Old Oct 26, 2006 | 07:33 PM
mvvette97's Avatar
make sure the vacume hose is on the map sensor. That will make it VERY rich if it is unhooked. Also try to unplug the MAF and see if it will start.
Old Oct 28, 2006 | 08:41 AM
the_merv's Avatar
Veteran: Air Force
I got it, Valves were too tight.. Runs like a champ now.
Old Dec 2, 2006 | 02:30 PM
Rothman's Avatar
your'e a dumbass
Old Dec 2, 2006 | 05:34 PM
Rothman's Avatar
jk bro
