Thump / Thud from Rear End during turns
Just like the subject says, when I take a right turn or left turn, I hear a faint thumping "thud-thud-thud-thud" coming from the rear. Mostly from the passenger-side. It almost sounds like the rear tires are hitting the sturdy plastic mud-flaps, but I highly doubt they are.
Any idea what it could be?
The 2001 WS6 has no suspension work, with the stock 275s filled to 30PSI.
you can lift the car and put it in neutral and turn the driveshaft...youll be able to tell if theres any noise coming from the diff....bushings are a little harder to tell if there bad....your car isnt tilted to one side is it?....and youve also made sure your spare is tight?..and the vats module isnt clanking against the frame?....the ws6 has the upgraded shocks so i wouldnt suspect a problem there....and you can get a pair of LCA's and a PHB for under 200 bucks together....
