View Poll Results: what brad of oil filter do you use?
AC Delco
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
94
24.54%
Wix
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
51
13.32%
Fram
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
30
7.83%
K&N
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
110
28.72%
Mobil1
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
67
17.49%
Generic
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
3
0.78%
Other
28
7.31%
Voters: 383. You may not vote on this poll
What kind of oil filter do you prefer?
#81
Originally Posted by BLKWS.6
I change my oil every 3-4K miles Patman, am I hurting anything but my wallet?
Changing it that often doesn't hurt anything, but it isn't really necessary.
#83
two comments first you should change your oil every 3000 even though the oil is fine and doesnt break down the additives do. 2nd someone should do a sticky on oil filter comparison on the filtering paper inside the oil filters. Thats how i would choose the filter if i knew which had the most filtering ability. My old shop teacher cut apart 5 different filters and rolled out the paper but that was 6 years ago and im sure they have changed from then.
#84
#85
#95
Originally Posted by Patman
Even if you do change your oil that soon (which you shouldn't, but that's another topic) it does still matter what filter you run. If you pick one that is restrictive to oil flow, and you drive your car hard, you'll get more engine wear compared to a higher flowing oil filter. In fact it's more preferable to choose a filter that flows better than it is to pick one that filters out the tiniest of particles.
