Sponsored by: CARiD
tranny question
Old Nov 2, 2006 | 11:02 PM
austin21's Avatar
Default tranny question
ok last night i posted about changing a tranny mount and i just want to make sure its the right thing to change but what happens it when im in 5th or 6th gear it does it in both but if i get below 55 my tranny starts to rattle alot also going from gear to gear has gotten tighter like i actually have to use some pressure to get it into third as opposed to when i bought it i could put it into third with a simple push so is this the right thing to change or is it something else .... ... thanks
Old Nov 3, 2006 | 12:21 AM
staringback05's Avatar
does it do it in a certain rpm regardless of gear?...if so thats probably your mount
Old Nov 3, 2006 | 05:57 PM
austin21's Avatar
sometimes but alot in either 5th or 6th ...but would that cause my shifting into gears to get harder
Old Nov 4, 2006 | 12:29 AM
no that would be the clutch.....
Old Nov 4, 2006 | 05:13 PM
austin21's Avatar
well that sucks hah...im going to go ahead and relpace the mount maybe i will get lucky but then again luck has never really been on my side
Old Nov 4, 2006 | 05:23 PM
austin21's Avatar
but there is no grinding or any signs of the clucth acting up othere then the shifting
Old Nov 5, 2006 | 03:59 AM
does it go all the way to the floor?, does it feel weird when it engages?..... just replace both the clutch and mounts.....stock clutch sucks anyway
Old Nov 5, 2006 | 11:57 AM
austin21's Avatar
its not a stock clutch its the ls7 ls2 fly wheel ...funds are a little low for that ...no it doesnt go all the way to the floor or feel weird
