Drivetrain/diff, Help!
edit: maybe a mod can reloacte this to the rear end section if they wish, due to my noobness.
if anyone doesnt know what a carrier bearing is, is the piece in the middle of a two piece driveshaft. The rubber surronding the bearing wears out and sags the driveshaft causing pressure on the bearing. eventually the bearing gives.
You also should have thrown an aluminum shaft in there from someone here.
No cbs, still fit in a v6 car, no need to make a custom. But you would have known that if you were on the right v6 forum.
i was gonna go with an aluminum, i was gonna drive to the dealership and buy one but they kept telling me it wouldnt fit. i said, yes it will. both shops i asked said no. I knew i was right, but just replaced it with oem to save time.
now theres a new problem, my starter
