Sponsored by: CARiD
Low Oil came on
Old Nov 6, 2006 | 02:08 AM
Camaro Ryder KV's Avatar
Default Low Oil came on
My Low Oil light came on after i raced twice, no oil on street, am i burning it through my exhaust?
Old Nov 6, 2006 | 10:10 AM
anyone?
Old Nov 6, 2006 | 11:22 AM
JohnnyC's Avatar
Well, if it's not leaking then it must be burning the oil. Not uncommon for the LS1.
Old Nov 6, 2006 | 11:25 AM
2001NBMZ28's Avatar
Oil level is fine? The sensor is on the passenger side of the pan - check the connection and wiring. Believe it illuminates when it thinks you're about 2 quarts low.
Old Nov 6, 2006 | 11:27 AM
JohnnyC's Avatar
I guess that I assumed you checked the oil level and it was indeed low. If it is full of oil then yes, you have a sensor problem.
Old Nov 6, 2006 | 12:39 PM
bradmb's Avatar
id probly move to a thicker oil. maybe it will help with some of the lose.
my car shut off when i got low on oil one time. the light never came on. but it illuminates when i have the key turned on without the engine on so i know it works. but my car is a 93, and its a chevy it will do weird things.
