Sponsored by: CARiD
Ah Crap! Green Coolant!
Old Nov 6, 2006 | 12:21 PM
382WS6's Avatar
Default Ah Crap! Green Coolant!
I had my car at the shop a few months ago. I don't drive it very often, so I haven't been crawling around in it much. The other day I was going to take it for a cruise. I opened the radiator cap and saw GREEN COOLANT!!! Apparently the "race shop" has never heard of dex-cool. I am going to flush it, but I'm just curious as to whether or not the green coolant damaged anything. Any ideas?
Old Nov 6, 2006 | 12:23 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
well, it is not supposed to be there because green eats ALUMINUM...flush it and add Dexcool or Prestone/similar Orange coolant.
Old Nov 6, 2006 | 12:29 PM
JohnnyC's Avatar
Just make sure you do a good flush and you will prob. be O.K.
Old Nov 6, 2006 | 08:09 PM
YoMommasTA's Avatar
BS green is fine.....dexcool is CRAP!.My camaro has 210 thous on it using the GREEN stuff and the rad inside looks like new.The crappy dexcool ATE the rad cap off my 36 thous mile TA!
Old Nov 6, 2006 | 08:44 PM
trackbird's Avatar
I've been using the prestone that will mix with either one and it's green. I agree that Dexcool tends to gum some things up (like my overflow, looks like it's full of mud, the cooling system looks new inside, it seems to oxidize when it mixes with air and turn to goop).
The green stuff is fine. They had aluminum blocks/radiators long before Dexcool and the world did just fine. I wouldn't run out and change it.
Old Nov 7, 2006 | 07:49 AM
_JB_'s Avatar
I'll never put Dexcool in a car. That stuff turned into a gel inside my radiator. I"m sure that was also the cause why I had to replace my waterpump at 45k miles.
Old Nov 7, 2006 | 08:03 AM
blkbird's Avatar
I have never had any issues with the dexcool being in there......
Old Nov 7, 2006 | 08:37 AM
trackbird's Avatar
My waterpump started leaking at 48k miles and was replaced at 65k or so. I can't say that I blame the dexcool, but it does seem pretty early to have one fail.
Old Nov 7, 2006 | 08:39 AM
Mr Incredible's Avatar
Most all modern green coolants are aluminum compatible. The only thing Dexcool may have over them is some extension of useful life. I do my coolants every two years anyway, so it doesn't matter.
Old Nov 7, 2006 | 10:28 AM
01Z28MN6's Avatar
yeah i'm running green coolant in my car. Going to keep it my car as well. Just need to keep on top of it, and keep it changed every so often. Not like it is that hard to do anyhow.
Old Nov 7, 2006 | 10:43 AM
_JB_'s Avatar
There was so much of a "gel" buildup I could hardly get the radiator cap off when I first got my car. The shops I went to get an estimate to flush the system all said the Dexcool will create the "gel" stuff.
Old Nov 7, 2006 | 10:46 AM
YoMommasTA's Avatar
it ate two rad caps before i realized what was going on,dexcool is garbage!
Old Nov 7, 2006 | 01:56 PM
NHRAMAN's Avatar
Exclamation
NO Modern GREEN coolant is safe for ALUMINUM...Read the labels..the ORANGE is fine....maybe some sponsor can speak up...Nothing wrong with Dexcool..just don't leave it in for years.
Old Nov 7, 2006 | 01:59 PM
NHRAMAN's Avatar
Question
Prestone GREEN ??? IT SAYS ITS FINE and COMPATIBLE for Modern Aluminum Engines.??? I have looked at that exact stuff and it says it is NOT. ??
Old Nov 7, 2006 | 02:00 PM
NHRAMAN's Avatar
Talking
Originally Posted by YoMommasTA
Bull Sheeet
There is a misspelling there. BTW..Guess what comes in the C6 ZO6.???....WHATEVER......
Old Nov 7, 2006 | 02:06 PM
ls1_doc's Avatar
What about GREEN extended life coolant. Green coolant is perfectly acceptable in your car as long as they did not mix the two coolants together. How many miles are on your car? I would not reccommend replacing the coolant in a vehicle with over 60,000 miles because they are different chemical make ups and the seals are broke in for whatever has been there to that point.
Old Nov 7, 2006 | 02:08 PM
SpaZMaN's Avatar
i agree, i work at a shop where we have green coolant that will mix with dexcool. go back to the shop and talk to them about it
[QUOTE=trackbird]I've been using the prestone that will mix with either one and it's green. I agree that Dexcool tends to gum some things up (like my overflow, looks like it's full of mud, the cooling system looks new inside, it seems to oxidize when it mixes with air and turn to goop).
[QUOTE]
Old Nov 7, 2006 | 02:10 PM
YoMommasTA's Avatar
like i said my camaro has 210 thous miles on it using the "GREEN STUFF" and it looks brand new inside.My TA on the otherhand was totally fkd by 36 thous miles using dexcool.SO lets see GET farked using dexcool or use the green and forget about it?
Old Nov 7, 2006 | 02:11 PM
ls1_doc's Avatar
What does that have to do with anything ? They have been using dex-cool in most gm vehicles since 95. Guess how many lawsuits there have been against it. Yet they still use it. It is good stuff if you are willing to keep an eye on it. The "goo" some people have described does not occour overnight. It does that because of exposure to air example ... bad radiator cap, cracked radiator tank, water pump leaking. ...
Old Nov 7, 2006 | 02:13 PM
YoMommasTA's Avatar
well i got two rad caps that were eatten by dexcool,both brandnew and within a few months turned into junk.Even ate the top of the radiator.FARK DEXCOOL!
