Sponsored by: CARiD
Need help bad!!!!!!!!!!!!!!11
Old Nov 6, 2006 | 08:24 PM
Rob's 02 SS's Avatar
Default Need help bad!!!!!!!!!!!!!!11
I went to minieke to get a coustom y pipe made.And i forgot to leave my key's.So they needed to move it out the shop to work on other cars.And automatic so they said they disconected something from the tranny and now when i i get on it the ****** tranny grinds.Help me out tell me what you think could be wrong.
Old Nov 6, 2006 | 08:27 PM
Pewterpower's Avatar
Probably the driveshaft, and then hooked it up 180* off.
Old Nov 6, 2006 | 08:37 PM
I duno cus what ever they did they hooked oi back up with pliers and lifted the car up wit a jack
Old Nov 6, 2006 | 08:42 PM
trackbird's Avatar
They probably took the cable off of the transmission so they could move the shift mechanisim out of park. Then, when they put the cable back on, they probably didn't get it adjusted properly.
That's my best guess.
Old Nov 6, 2006 | 08:45 PM
Thats what they did how do i adjust it.
Old Nov 6, 2006 | 08:46 PM
You sure it's not more of a vibration, or a rattle? Cuz if they just unhooked the selector, it wouldn't grind, unless they gorilla torqued on it to find neutral.
Old Nov 6, 2006 | 08:50 PM
staringback05's Avatar
heres something a little better....take it back to them....since THEY did something to it...and tell them to fix it
Old Nov 6, 2006 | 08:57 PM
Well tell u the truth its a heavy vibration and rattle.
I dont want them to touch my car agiain thats why.
Old Nov 6, 2006 | 09:16 PM
How do i adjust it?
Old Nov 6, 2006 | 09:27 PM
Tainted's Avatar
for christ sakes take it back to them. say fix it or have fun with a lawsuit
Old Nov 6, 2006 | 09:55 PM
trackbird's Avatar
Well, I'd make them fix it, but that's just me.
The easy way is to look and see where the bolt was before. There will be a mark or a clean spot, loosen it up, line it up and tighten it down in that spot. That's probably all you need to do, unless there is other damage or something has been damaged by driving it while out of adjustment.
