Sponsored by: CARiD
How to clean intake manifold?
Old Oct 31, 2006 | 11:44 AM
Spectator's Avatar
Default How to clean intake manifold?
I'd like to clean the gunk out of a used LS6 intake and put it on my car. What's the best way to clean the insides out? Also, what should I look for on the gaskets to see if I need to replace them? Thanks.
Old Oct 31, 2006 | 11:50 AM
Tainted's Avatar
replace the gaskets
Old Oct 31, 2006 | 11:51 AM
Cerebrex's Avatar
They are reusable gaskets. Just make sure they aren't brittle and don't have any cracks.
Old Oct 31, 2006 | 12:11 PM
staringback05's Avatar
ok ok.....you can use a throttle body or carb cleaner, it will break down that gunk and run it out.....secondly...if you have the gray gaskets get rid of them, they dont give you as good of a seal as the red ones....there you go
Old Oct 31, 2006 | 12:42 PM
yes...the ls6's are slightly larger/different....like i said just make sure you get the red ones
Old Oct 31, 2006 | 12:43 PM
Spectator's Avatar
Thanks for the heads-up, guys. Just to make sure I'm getting the right gaskets, it's the LS6 gaskets I'm looking for, right?
LS1 intake manifold gasket set = 12524653
LS6 intake manifold gasket set (contains 8 gaskets) = 12533587
Old Oct 31, 2006 | 02:33 PM
SoCalZ28's Avatar
1 can of Seafoam Deep Creep
Old Nov 1, 2006 | 09:38 PM
Spectator's Avatar
Is it a bad idea to replace the intake gaskets with Fel-Pro brand gaskets? Should I be looking specifically for the exact GM part number?
Old Nov 2, 2006 | 12:47 PM
slt200mph's Avatar
123,000+ miles on gray gaskets that have been on 3 different intakes without any leaking or problems...if they are still plyable and have no cracks in them they are good to go..
Old Nov 2, 2006 | 09:14 PM
^^^^ didnt say they wouldnt "work"....but you can honestly take the gray ones and the red ones and sit them together....the red ones stick out at least 1/8 inch...where as the grays are flush....thus the better seal would come from the reds....and stick with gm....dont go throwin on some other gaskets...
Old Nov 3, 2006 | 03:10 PM
slt200mph's Avatar
What is a better seal???...it is like being pregnant..it is either sealed or it is not..the symtoms of a vacum leak are very evident if you have one ... nuff said dude..
Old Nov 4, 2006 | 12:06 AM
....so all gaskets are created equal?
Old Nov 6, 2006 | 07:43 AM
slt200mph's Avatar
I do not know about he civil rights of the a for mentioned gaskets.. ..but no matter what color they are if they are pliable and not cracked they will work..sealed is sealed..if you do not have a vacuum leak it means they are working properly.. I rest my case..
Old Nov 6, 2006 | 08:59 PM
ehhh still not convinced....jurys out....
Old Nov 7, 2006 | 08:02 AM
slt200mph's Avatar
Parts departments and parts stores love guys like you..those that know just laugh..this post has become a waste of time..Im out..
