Recommend me an Oil (yes another one)
Tech Resident
Originally Posted by RPM WS6
I have 2 NAPAs in my area, I'll check again but I'm damn near positive I didn't see it there before. Oil selection seems to be slim in my area. I'm lucky just to be able to find the M1 0W40.
LS1Tech Administrator
Received 1,706 Likes
Originally Posted by ChocoTaco369
lol no you're not. 0W-40 is hardcore mainstream oil. even wal mart has that stuff
I think 5w30 purp. I used to use 5w30, but then switched to 10w30 when my oil pressure started getting lower than expected. but i think im gonna switch back b/c my pressure is too high now. its above 60 on cold days. and doesnt dip below 30 much. but i also have a completly different motor.
So you might think, but you'd be wrong. The Walmart by me doesn't even have a spot for M1 0W40 anymore. They used to, but not in the last 6-12 months.....
Yep, noone here carries it either. I had to get 10-30 Syntec. So far the car likes it okay I guess. has not burned a DROP in 800 miles.
Tech Resident
only at cold startup. at operating temperature, they are both exactly the same.
in 10W-30, it is a 10-weight at cold startup and 30-weight at operating temps.
of course if it's mobil 1, it's really more like 0W-20 because it's so damn thin.
#33
Originally Posted by Unlimited
German Castrol synthetic (European oil) hands down!!! I've tried several different oils, and not only did this oil work good in both cold and hot weather climates, it stopped the famous ls1 oil consumption, AND THE CAR LOVES IT.
no; oil didnt stopped the famous ls1 oil consuption. you might have reduced it lil bit but your ls1 will still burn the oil.
unless, you have a vaccumm pump setup with catch can.
