Sponsored by: CARiD
broken header bolt
Old Nov 7, 2006 | 08:44 PM
Darbadocious's Avatar
Default broken header bolt
the #2 bolt on the passenger side broke while going in. i know, i probably crossthreaded it. it looks like the remainder of the bolt is flush with the head. how long will i be able to drive before this becomes a problem, and how big of a problem is this.
Old Nov 7, 2006 | 09:11 PM
Tainted's Avatar
you really should have the top welded on it and get that bitch out it canc ause a potential leak
Old Nov 7, 2006 | 09:26 PM
98camaroLS1M6's Avatar
with the stock metal gaskets, the exhaust will seal with 4 out of 5 bolts.
Old Nov 7, 2006 | 09:28 PM
Tainted's Avatar
I dunno about you but id still want that bolt in there
Old Nov 8, 2006 | 05:31 AM
yea i used the metal gaskets and the other 5 bolts are in good. it's just a bitch to work in there so if i don't ablosutly have to get it out i'm not gonna mess with it.
Old Nov 8, 2006 | 05:46 AM
Somebody09's Avatar
wtf is the problem with removing this broken bolt?
Old Nov 9, 2006 | 07:35 AM
PopaPork's Avatar
Get some IRWIN screw/bolts outs, work like a chhhharm.
Old Nov 9, 2006 | 12:42 PM
ls1amit's Avatar
i have a few friends that have had the last bolt on the driverside on thier header install break and guess what they seal fine i wouldnt worry about it as long as its that one just tighten that header down!
