Sponsored by: CARiD
I'm an idiot
Old Nov 14, 2006 | 02:54 PM
09CPTN's Avatar
Default I'm an idiot
Well, after freeing my drain bolt for the oil and letting it drain I went after the filter. After an hour of turning and cussing I realized I was TIGHTENING it . What an *** I am. So now i've got a 98 T/A on Rhino ramps, with no oil in it and a crushed, death-grip tight filter . Feel free to have a hearty laugh at my expense gang, I deserve it.
Old Nov 14, 2006 | 03:41 PM
Craiggg's Avatar
LoLz ) I did that the first time I took my filter off.
Old Nov 14, 2006 | 03:46 PM
09CPTN's Avatar
I have a stronger guy coming over to help me out. Hopefully he can get it off. I feel like a mere husk of a man .
Old Nov 14, 2006 | 03:52 PM
Revelation Z28's Avatar
lmao!
left-loose
right-tight
Old Nov 14, 2006 | 04:22 PM
2001NBMZ28's Avatar
Get an oil filter wrench, or you can loosen it by piercing it with a screw driver and turning - be extremely careful with the latter method.
Old Nov 14, 2006 | 06:51 PM
taintedmeat's Avatar
Word, try an oil filter band wrench, of if it's actually crushed flat maybe a pair of vice grips.
Old Nov 14, 2006 | 06:52 PM
09CPTN's Avatar
Update: Friend came over with a filter wrench that fit, the filter came off. Got all the new oil in and the new K&N filter installed. My car tested full at 5.5 quarts, even with the long filter. Oil pressure is up 10-15 psi at idle(Car had shitty Kendall GT-1 SemiSYN when i bought it). I also seafoamed the oil prior to this change, and as I was told, it came out pretty dark. I noticed that after the GC went in that my car had the dreaded piston slap(never had it before). But it went away. IS it normal for the slap to come and then go like that? Also, is that piston slap that I hear harmful? And by the way guys, thanks for not laughing too much at my filter mishap.
Old Nov 14, 2006 | 06:53 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yeah that was the best laugh of my day.
Screw driver method works great. If the other guy can't get it off.
Old Nov 14, 2006 | 09:51 PM
382WS6's Avatar
Good thing you got it off... I was going to suggest pulling the motor and replacing it with another motor that didn't have an oil filter seized to it
Old Nov 14, 2006 | 11:22 PM
Old Nov 15, 2006 | 01:13 AM
CASHss99's Avatar
i think at least everyone has dun it once
Old Nov 15, 2006 | 10:07 AM
gtarist's Avatar
You'll get noise after an oil change until the oil is distributed throughout the engine.
Old Nov 15, 2006 | 01:46 PM
joecar's Avatar
Talking
Originally Posted by Revelation Z28
left-loose
right-tight
lefty-loosy
righty-tighty
Old Nov 15, 2006 | 02:31 PM
8GTOKLR's Avatar
Originally Posted by joecar
lefty-loosy
righty-tighty
when your on the left side or right side. I have a lefthanded filter wrench
Old Nov 15, 2006 | 02:34 PM
GregWS6&z28's Avatar
i always put my filters on kinda tight. i've had to punch a screwdriver quite a few times.
Old Nov 15, 2006 | 04:56 PM
09CPTN's Avatar
I just wanted to giva a "thank you" to all of the members on these boards that reccomend the GC 0-30 and K&N HP2006 filter combo. It may cost a little more to go that route, but i've now got better oil pressure and a quiet motor.
Old Nov 15, 2006 | 05:05 PM
2001NBMZ28's Avatar
and the filter has a "nut" built in - easy to remove...
Old Nov 15, 2006 | 06:38 PM
It's a great combo, been running it for almost 2 years now(not the same oil and filter the entire time)
Old Nov 16, 2006 | 06:44 PM
Camaroz's Avatar
Anyone else catch this? That's pretty out of the norm for oil pressure.
Old Nov 16, 2006 | 06:50 PM
RPOWU8's Avatar
I think he means it's higher by 10 to 15 PSI than it was before.
DJ
