Speedometer not Matching Trip Odometer
And as for the site. When it lists the chart on the right, what do all the numbers exactly mean? Use those numbers to program it? Or is that how fast your going at those RPMs in whatever gear?
Sorry for so many questions.
Thanks again.
It's easy, just get under the car and mark the driveshaft and position of the wheels....
Turn the driveshaft and count the number of rotations it makes before the tires make one complete rotation...
If say you had 3.73's, the driveshaft would turn about 3 and 3/4 turns before the wheels made one full turn....
If you had 4.10's, the driveshaft would make a little over 4 turns before the wheels make one full turn....
Note, when doing this test, make sure both rear wheels turn evenly....
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
Rick
And thanks 2001NBMZ28. Will do.
Sounds more like you have 3.23's in there then
Perhaps someone slapped an A4 rear in there before you bought it?
Do the driveshaft test and you'll know for sure....
Rick
Rick
Now, you will need the circumfrance of your rear tires in feet. For an example, if your rear tires are 84.5 inches around, that is 7.04 feet.
Here is the way to figure:
1. Tire circumf. (in feet) times RPM (at a given speed)
2. That answer divided by 5280.
3. That answer times 60.
4. That answer divided by the speed at the given RPM in number 1
5. The answer will be your axle ratio.
my car with 3.42's in 5th gear doing 60 my rpm is right around 2100-2200 rpm and 6th gear at 60 it settles down to about 1500 rpm
