Flushing engine oil?
Pay strict attention to oil pressure and all engine noises. Anything unusual could indicate a restricted passage or improperly lubricated bearing surface due to dislodged sludge or debris. Do not continue to drive the vehicle if either happens.
BG demostrated their engine oil system flush for our shop using a 350 SBC. This method will work great on a clean engine. However, if there are any metal shavings or a large amount of sludge on the top end, this method actually traps it on the wrong side of the pickup tube screen. Rather than being harmlessly deposited on the bottom of the oil pan, it sits on the pump side of the screen waiting to be sucked up into the oil pump, possibly causing oil pump damage or complete failure!
