Sponsored by: CARiD
I broke something
Old Dec 6, 2006 | 03:41 PM
blackhawk J's Avatar
Default I broke something
I was pulling out my starter and broke the outer bolt off in the hole. I drilled it and attempted to use a tool to reverse thread tool to pull out the broken part of the bolt out of the hole.
I threaded the tool into the hole and I aparently turned too hard and cracked all the way up the starter mount!
Now I am freaking out because this piece is cast as part of the engine and I cant bolt on my starter.
Has anyone else had this situation? Any direction would be appreciated...
Old Dec 6, 2006 | 05:07 PM
staringback05's Avatar
ewww...thats rough...if its actually cast as a part of your engine there not MUCH you can do....you might want to get hold of someone at the dealership or a good mechanic who could guide you in the right direction...i myself can think of much for a alumn. block....
Old Dec 6, 2006 | 08:39 PM
88zukon36s's Avatar
Last week i saw a 2000 vette with the same problem. They said they were gonna get someone to weld it back together, alumnum is easy to weld if the person knows how.
Old Dec 6, 2006 | 09:35 PM
thats the key....if someone knows how....to many dont know what there doing with alumn blocks and they half *** weld.....its gonna cost you one way or the other
Old Dec 6, 2006 | 10:53 PM
Craiggg's Avatar
Jb Weld Lol :p =\
Old Dec 7, 2006 | 06:49 PM
SoCalZ28's Avatar
While I worked at a local Chevy dealer we had a someone bring in a truck with the same issue. You have 3 options, get someone to alumn. weld it,
Originally Posted by Craiggg
Jb Weld Lol :p =\
or replace it. Whatever you do, its gotta be strong that starter bolt sees ALOT of torque... Wish you luck!!
Old Dec 7, 2006 | 09:41 PM
01WS6/tamu's Avatar
New block time you are screwed for the most part anything above is only a temporary fix.
Old Dec 7, 2006 | 10:09 PM
1badchicken's Avatar
WOW, man there is no room to play with either, They are all temp fixes.
