I installed a temperature sensor and I believe it is leaking. I did it in an fbody which has a convenient place for installation. The vettes have a stock oil temp sensor on the ls1's so i tapped the removable piece. The sensor asked for 1/8 npt threads. My friend drilled and tapped it, he did an awesome job. I used some teflon tape to make a good seal and tightened the sensor all the way up.
For some reason, it is leaking, what can i do? Should I try removing the teflon tape and just going metal to metal, or possibly using loctite on those threads?
Here is a picture of what I am talking about
http://www.xse.com/leres/ss/images/cover-sm.jpg
