Any problems switching to Amsoil oil?
also have you change your fuel filter lately?, a clanking could be because of dirty gas when revved
Recently there was an excellent thread over at BITOG that shows how well the AMSOIL 10w-30 has been working in the LS1. 5000 miles with some racing and very little wear. Now that is something to judge an oil by.
Thread: http://theoildrop.server101.com/foru...&Number=779784
AMSOIL 10w-30 ATM: https://www.amsoil.com/storefront/atm.aspx?zo=1436102
German Castrol has produced the best wear numbers but is hard to find in most areas.
As far as letting the tank go down, I never let it happen but this one time I was in a bad neighborhood and it was late at night so I drove home with the check gauge light on. What do you think would be the best thing to do now? BG in the tank or full service at the dealer fuel injection? New fuel filter before or after the cleaner?
With the stock pump or one that is fitted with the venturi like the stocker, You CAN drain the tank. So if you didn't run it dry, you are probably fine. And since you didn't mention pushing the car through a rough neigborhood, I guess you didn't run it out.
Get some good gas and run a tank through it and see if it keeps running roughly.
Run cleaner first and then do a filter again, if you want to.
Thanks.
