Sponsored by: CARiD
When is the clunking in the Diff normal?
Old Dec 16, 2006 | 07:31 PM
oifish's Avatar
Default When is the clunking in the Diff normal?
I heard that having a clunking differential is normal with F-bodys. Mine does it, but I want to know if its the normal clunking or if its something going bad.
Ill try to describe it:
It clunks from about 10 mph to 30 mph any faster there is no sound, it dosent clunk under hard acceleration, it also dosent clunk when turning.
Is it normal?
Old Dec 16, 2006 | 07:49 PM
WayneSS01's Avatar
Yep normal. Mine does the same. It is a low tone clunk like rocks in a box. I am the one owner of the car and have never thrashed it.
Old Dec 16, 2006 | 11:14 PM
00slowredz's Avatar
im sorry man im not trying to hijack the thread but that kinda worries me....mine clunks when im off the gas just coasting at low speeds and when i turn at low speed. it may be doing it all the time, maybe i just cant hear it over my exhaust???
Old Dec 16, 2006 | 11:40 PM
keliente's Avatar
When you have a torsen
Old Dec 18, 2006 | 01:53 PM
dailydriver's Avatar
It is perfectly normal for Torsens to "clunk" or make the muted "rocks in a box" sound on off throttle "coast down" as noted above. This is due to their worm gear design. If it makes A LOT of noise otherwise (I.e.; NOT on coast down) there may be a problem.
But the O.P. has a '94, so if he still has the stock/original Auburn (that's what they came with, right?) and it is clunking, there probably IS a problem.
Old Dec 28, 2006 | 05:57 PM
mike247's Avatar
Default rear end noise
I had the same prob slow down or down shifting grinding or vibrating sound turned out my pinion gear was loose and was eating up my lsd and gears had to replace my pinion shaft gears lsd and one axle shaft
