Sponsored by: CARiD
Anyone have issues with Prothane mounts?
Old Dec 19, 2006 | 07:37 PM
Sneakyws6's Avatar
On the tree
Default Anyone have issues with Prothane mounts?
I replaced my transmission mount tonight with a Prothane mount. I had replaced my factory one with a new factory one about a month or so ago and was still having all sorts of issue with thumping under the car under hard *****.
Well the Prothane took care of that, but now I have some nice noise and vibration. Has anyone found a way to quell the noise any? I was thinking some 1/4" rubber on both side of the mounting surfaces might help it some.
I had read on LS1Tech that some peeps had encountered some Knock Retard running mounts like these due to the ECM picking up the extra vibrations.
Anyone else have any ideas.
Old Dec 20, 2006 | 11:56 PM
98boxer's Avatar
I remember when i first installed my prothane tranny mount. At first the vibration was loud in 3 rd gear and in regular drive (D) it vibrated after 120. About a month or two later the vibration are hardly noticable from when they were extremly noticable. I wouldn't do nothing, i didn't and with in time the prothane settles in. And imo, they are very well needed. Before the prothane i broke two factory tranny mounts. If you can, replace the torque arm rubber mounts with prothane too, and you will be happy you did, car reacts a lot better with prothane mounts on the torque arm too.
Old Dec 21, 2006 | 06:55 AM
Sneakyws6's Avatar
On the tree
I have the one for the torque arm mount, just need some time to remove the y-pipe in order to put it on.
I hope it breaks in, I dont mind some extra noise per say, but this is a little on the extreme side of things.
Old Dec 22, 2006 | 01:30 PM
rich Z's Avatar
I had a Prothane trans mount and the noise and vibration was very bad so I instaled washers on the crossmember to lower the trans somewhat which then cracked the mount. I then installed a Energy Suspension mount and it was about half as bad. When I had a new clutch installed 18 months ago I got another stock mount but now I think it's torn since I get clunking upshifting and downshifting just as I did when the original mount tore.
Old Dec 26, 2006 | 08:34 AM
brad8266's Avatar
You might need new engine mounts.
