Sponsored by: CARiD
View Poll Results: Motor Mounts
Rubber (1LE)
3
11.11%
Poly (Prothane)
22
81.48%
Solid (Spohn)
2
7.41%
Voters: 27. You may not vote on this poll
Solid Vs Rubber Vs Poly Motor Mounts
Old Dec 29, 2006 | 05:53 PM
ChicagoTransAm's Avatar
Originally Posted by JD_AMG
Hmm... Could the bang also be described as a 'clunk'? Im asking because sometimes I get a clunk, which I can feel through the shifter. Like if I stomp on it in 1st, then release the gas really quick I get a kinda clunk, and I can feel it in the shifter. Or if I release the clutch to quickly I get the same clunk. I thought maybe it was because the tranny mount was allowing the tranny to move too freely, and it was hitting the floorpan or something...
Yep... however, the trans mount replacement didn't help
Old Dec 31, 2006 | 01:11 AM
nick_4.8sierra's Avatar
Is there any difference between Polyurethane and Prothane, or is this the same material? I thought Prothane was a little softer than Polyurethane, am I wrong? If this is the same thing why do some products say thier polyurethane mounts and some say thier prothane mounts?
Old Dec 31, 2006 | 04:30 AM
Prothane is just a brand... they make poly bushings/mounts etc.
Old Jan 3, 2007 | 07:16 PM
V6 Bird's Avatar
Originally Posted by BIG BAD BLACKSS
Maybe he can use a chain or turnbuckle to hold the motor while he's at it! Im sure it works perfectly fine, just seems ghetto fabulous to me.
These are far from ghetto dude. Done very clean actually.
Here's the pics of my solid stock motor mounts.
http://i30.photobucket.com/albums/c3...k/HPIM0606.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0605.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0604.jpg
enjoy and ask questions at will.
Old Feb 1, 2007 | 04:48 PM
SUX2BU's Avatar
I tried that a few years ago, But they were too heavy so i made my own. Then those were too heavy so i made them out of aluminum.
https://ls1tech.com/forums/generation-iii-external-engine/408140-solid-motor-mounts-part-2-a.html
Old Feb 2, 2007 | 09:15 AM
squealingtires's Avatar
+1 For stock rubber motor mounts. Rubber mounts will "wear out" after many vibration cycles and will lose their elasticity so they will need to be replace every so often. Plus having an engine that "gives" a little reduces the shock load to the rest of the drive train esp. for a manual transmission
Old Feb 2, 2007 | 06:10 PM
hardtopz28's Avatar
Not to hijack but I just ordered some polys if anyone wants to chime in and give me a run down on how they did it would be greatly appreciated
Old Feb 2, 2007 | 11:26 PM
z28bryan's Avatar
I got polys put in. With a 400 rwhp heads/cam setup mostly all I noticed was that my shifter wasn't wobbling around everywhere anymore and that my headers weren't banging the undercarriage. The vibration at least in my case is.... I don't know I'm still wondering what this vibration is that comes with the polys.
