Detonation Problem Again
Im having a modest amount of detonation at low speeds. Ive had our clubs computer man take some of the timing out.
It worked for a while & its back again.
I cant keep on having computer man take timing out, Im gonna lose more power. I cannot afford to have a full dyno tune right now.Should I fill it up with 100 octane? ($6.00 a gallon)
Or should I just get an octane booster?
I use good gas usually 91 octane from Shell. I also take very good care of my car. Im also having a new fuel filter shipped to my house, its been driven about 10,000 miles since the last time I had it replaced.
As far as this goes, what do you think?
Turn the ign on but do not start the car.
Go under hood and open both of the fuse blocks.
Pull the PCM BAT and PCM IGN fuse. Leave the fuses out for a couple of minutes.
Turn ign off then replace the fuses.
Turn ign on and start car. It may or prob will stumble at first. You can kill the car and the turn the ign on and restart it again and it should start just fine. Now go out and drive it for a little bit so the ECM can start the relearn process.
Exhaust can cause false knock to occur. I would first run some seafoam through the intake to clean the piston tops, and give the car a good tuneup if it hasnt had one lately (plugs, wires, fuel/air/filter, pcv valve). Throw some 100 octane in too to see if it goes away.
If all that does not do the trick you might want to use software to desensitize the knock sensors some.
My headers and x pipe cause false knock so i desensitized the sensors 10% and it stopped pulling timing.
SW LT headers
SW catted Y-pipe
Magnaflow catback
K&N filter
Also, the round filter behind the airbox is clean.
Sneaky, Im going to try that.
Ill get back to this thread.
SW LT headers
SW catted Y-pipe
Magnaflow catback
K&N filter
Ditch the K&N filter also and switch to a paper filter, the oil from the K&N can go through and get on the MAf wires which can screw up your fueling and can cause the symptoms you have. By the way that round filter that you are talking about is not a filter, it is a air straightening screen for the MAF sensor.
What you want to do is clean and lightly oil the air filter (or like i said just get rid of it and get a paper filter), and take the MAF out and clean it with electrical contact cleaner, then reinstall it all and see what happens.
When was the last time you changed the plugs/wires and fuel filter?
I just went through the steps myself with the PCM stuff.
I did notice alot more pickup, but as far as the detonation its a LITTLE better.
Im going to the auto shop right now and picking up a paper filter.
Now that I think about it seems like when I installed the k&n filter thats when all this started.
As far as the tune-up goes I just had my spark plugs replaced about 3 weeks ago.NGK I believe, Master of Disaster puts those in all our cars.
I just recieved my new fuel filter in the mail & its getting installed tommorow.
Im not sure about the wires because when I open the hood all I see is wires.
There are some long wires on the left of the engine that look brand new.
I will keep you posted.
Also, I know for a fact I have detonation because of my dyno results.
I also agree with Brad it might be false detonation. Thats what I think he is trying to explain.
I did install a paper filter. I have not driven the car enough since then to really tell the difference yet.
Whats funny when I took out my k&n filter it was DIRTY & I just cleaned it the beginning of Dec.
Im going to also check on the knock sensors.
If this problem gets fixed I will definitly have computer man program my timing back in.
Whatever saves me from having to get a full dyno tune. I cant afford that right now.
I am running 91. If I was rich Id be running 100 octane but at $6.00 a gallon I dont think so.
he melted 3 plugs.
