Buying a 98 vs. 99+
There have been some minor changes over the '98-'02 years. Some were improvements, but not all were good changes though (some were a step backward). Only issue that might cause you some extra hassle with a '98 if you plan big mods is the tuning situation mentioned above.
Check out this link for more info if you haven't already:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
really if you go through the list, the biggest difference of changes 98-02 is that 01-02 cars have an ls6 intake, and 98-99s have a smaller gas tank by about a gallon.
the own downside of a 98 in my eyes, is that they do tend to blow up AC compressors at WOT, i finally found the TSB after a year of searching (or not searching)...
2002 had a lot more rattles and squeaks and the T-tops leaked.(bought new)
1998 seems to run harder(stock cam for 1998 has higher lift? I heard), tight as a drum. The seat belts on the 1998 seem to get hung up twisted all the time, like the bracket does'nt let the seat belt retract right.
When I buy my next one, I'm shooting for 2002 only because it is newer.
you are correct it will freewheel if you turn it off. but 99-02s turn off by themselves after a target rpm has been reached, 98s frequently miss the target rpm, they dont tell you that though...
The '99-'00 injectors are the smaller 26lb.
