Sponsored by: CARiD
Hard starts...sometimes
Old Jan 9, 2007 | 08:32 PM
Tainted's Avatar
Default Hard starts...sometimes
1996 Z28 camaro. new alternator, battery, and plugs. has 120k miles on it. sometimes it just doesnt want to start like its flooding. you can keep trying to crank it and give it some gas and it will eventually. if you stop trying to crank it, it will buck and act like its trying to, and you can hear the intake sucking in air.
Also this *normally* only happens on the first crank of the day or when its really cold outside. when the car does start though black smoke comes out the back. BUT it will drive fine after I get started, and you can turn it off and crank it right up without a problem.
Any ideas on this one guys? Gramps suggested possibly a cold crank sensor
Old Jan 10, 2007 | 04:44 PM
Tainted's Avatar
bump for the day
Old Jan 10, 2007 | 05:06 PM
Tainted's Avatar
ok I havent cranked it at all today but I got an aftermarket MAF
Old Jan 10, 2007 | 07:56 PM
DrkPhx's Avatar
Could be the VATS. I had an intermittent starting problem and when I disabled it the problem went away. You will need tuning software to turn it off.
Old Jan 10, 2007 | 08:09 PM
Tainted's Avatar
ok i tried the maf sensor thing. it started quicker than it normally does but still gave me a slight problem.
Old Jan 11, 2007 | 03:13 PM
Tainted's Avatar
Originally Posted by 96slow6
I am sorry i would love to finish what i started but im from the other site ya'll hate now i guess. I have deleted all my other posts already except this one. I will delete it as soon as i know you hav got this message. Once again i am very sorry but i have to side with what i call home.
do what?
Old Jan 17, 2007 | 05:49 AM
beeker82's Avatar
this is exactly what my car is doing right now, I need help trying to figure this problem out
Old Jan 17, 2007 | 04:02 PM
Tainted's Avatar
im starting to think its my MAF. it could be telling the pcm to dump more fuel in and make for a rich, hard start since it ONLY acts up when its a cold start. it will run fine all day long except for the first crank of the day.
Old Jan 18, 2007 | 12:33 AM
beeker82's Avatar
my car is speed density so there isnt a maf,I dont get it though my car is doing exactly what yours is doing
Old Jan 19, 2007 | 12:06 AM
beeker82's Avatar
ttt anyone else have an idea what the problem could be?
Old Jan 19, 2007 | 10:39 AM
lastcall190's Avatar
I had the same problem on my 94, changed the FPR and it started like a dream. Try that, nice cheap fix!
-J
Old Jan 19, 2007 | 11:35 AM
Tainted's Avatar
-J
whats the FPR?
Old Jan 19, 2007 | 11:57 AM
Sorry, Fuel Pressure Regulator.
Old Jan 19, 2007 | 02:12 PM
Tainted's Avatar
ahhh ok, any idea how ahrd that is to change and how long it normally takes?
Old Jan 19, 2007 | 03:06 PM
We changed it on my friend's LT1 car in under an hour, just relieve pressure with the schrader valve, may/maynot need the fuel line removal tool, it was TOO long ago. Easily accomplished in the garage, just be prepared for some gas to spill unless you're real careful/lucky I think the directions were on the shoebox site for the f-body, but I can't find the address right now.
-J
Old Jan 19, 2007 | 04:14 PM
Tainted's Avatar
awesome thanks
Old Jan 19, 2007 | 07:22 PM
NP lemme know if it works or not...
Old Feb 10, 2007 | 05:17 AM
qwik_ss's Avatar
I have the exact same problem but with my 98. Let me know what fixed the problem so I can try it on mine. Thanks
Old Feb 10, 2007 | 11:56 AM
Tainted's Avatar
i aint tried anything on it yet. unplugging the MAF sensor seemed to help a tiny bit
Old Feb 11, 2007 | 12:15 AM
fuseone's Avatar
try this turn the key to the on seting dont crank the engine try it a few times in a row and see if it starts up then. because it could be with the fuel pump
