Sponsored by: CARiD
Trunk Pop
Old Jan 12, 2007 | 01:22 AM
Transamin00's Avatar
Default Trunk Pop
anyone else have the problem of the rear hatch not being openable after you hit the button? i have to use the remote, and hit the button as im trying to lift the hatch up.
Old Jan 12, 2007 | 04:40 AM
gonefishn1212's Avatar
just hit the button twice.... even b4 you go to lift the hatch, it should be completly unlatch if you press the button twice
Old Jan 12, 2007 | 05:02 AM
w02ramair's Avatar
There is a spring replacement writeup somewhere out there.
Old Jan 12, 2007 | 05:20 AM
SpaZMaN's Avatar
i have to pop it, pull it up, and hit the button agian, it pisses me off! where is this write up?!
Old Jan 12, 2007 | 08:31 AM
WADDISME's Avatar
Here is the link. I have the spring, but haven't had my cover off to add spring yet, but I have the spring.
http://www.installuniversity.com/ins...sity/index.htm
Let us know if it works.
Old Jan 12, 2007 | 08:37 AM
3800RS's Avatar
try turning the rubber stops so they sit up higher
Old Jan 12, 2007 | 08:53 AM
Tudds's Avatar
I have to press mine about 5 times and sometimes it still doesn't come up all the way
Old Jan 12, 2007 | 02:31 PM
Zentenk's Avatar
Yeah, doing this helps but it looks retarded.
Old Jan 13, 2007 | 10:27 PM
618HAWK's Avatar
I have a few extra of the correct springs that take care of the problem. Easy 2min install. With one hit of the button, and hatch pops way up, well out of the latch assy.
Buck or so and cover the shipping and it yours. PM
Old Jan 15, 2007 | 08:13 AM
Flamin' bird's Avatar
I have to hit mine probably 100 times and it doesnt work . I have to lift up on the hatch and press the keyfob button to open it . Mine is a faulty piece in there though as we found out when I swapped hatches. I need a whole new mechanism .
Old Jan 15, 2007 | 10:17 AM
BlackHawk T/A's Avatar
Yup I have to hit the button on the remote twice, while pulling up at the right time. Sometimes it requires another click before it will let go.
Old Jan 15, 2007 | 04:39 PM
jimmypop13's Avatar
The extra spring mod doesn't work for very long. I added mine probably 5 years ago & it maybe worked for a year, and its the same spring they used from Lowes. Now it's the same as it was, I have to push it once so it partially comes up, and again to get it to release the hatch
Old Jan 18, 2007 | 06:45 PM
3.4camaro's Avatar
you dont replace, you add on. have 2 springs.
Old Jan 18, 2007 | 08:28 PM
Flawless02SS's Avatar
I did the spring mod too, I piggy-backed it to the stock spring and it only worked for a year. Now i'm back to 2-4 button presses. This **** pisses me off!
