Amsoil 5W-40
Originally Posted by Cobra4B
Whoever said it will flow worse when cold is wrong... when cold it performs like a 5wt oil. The first number is the cold viscosity rating. When cold a 5w40 and a 5w30 will perform the same, when hot the 5w40 will be thicker.
Originally Posted by chevygirl
My idle seems to be rougher since the oil change. It isn't missing or anything just seems like it shakes a little more. It is cold here now. Maybe after is warms up it won't do that. Anyone else noticed their car running different when they changed brands or weights?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
So dailydriver it doesn't hurt anything to hear so much noise when cold. I let it warm up before I drive it. It is suppose to get back up now to lows above freezing. Maybe I should have chosen the Amsoil 30w but I planned on running it for 6-7 months which would be warmer weather. What is the cst at 40* on the 5w-40 Amsoil? I changed from 10w-30 Mobil 1 to this. In the past on my vehicles I ran 10w-30 dino oil all year long. I have a truck with a 350 engine. This car is more sensitive and is noisy.
Relax, your car will be just fine. The AMSOIL 5w-40 is a great choice for your conditions all year round. 30*F is NOT that cold. Many people run a 5W and do start ups in -10 to -20F temps every morning.
I run the 0w-30 but this morning at 0F my Silverado started like it was 60F.
The specs for your 5w-40 are here: http://www.amsoil.com/StoreFront/afl.aspx?zo=1436102
Ken
I run the Amsoil Euro 5w-40, its great stuff. Better pressure, less startup noise, etc. But I always let the car warmup before driving it around, so I wouldn't hear much noise anyways. Its a hell of a lot better than the dino junk that was in the car when I bought it.
Based off my experiences from last year, I'd recommend not going one whole year on the stuff. It seems like it got really thick, dirty, and more noise was prevalant on startup than usual. Seems like the extra noise started about 9 months into the cycle.
Well it has been 2 weeks and the car seems to be doing fine. Lowest oil pressure is like 35. The piston slap seems to be better when it is a little warmer outside. Drives fine. I seem to be not getting the same fuel economy and I won't know for sure until I go on a trip. I don't know if that is possible to have less fuel economy on this oil. I was getting 25 or better hwy. Just thought I would give an update.
