Sponsored by: CARiD
very high pitched noise from engine?
Old Jan 14, 2007 | 06:34 PM
CAMAROZ28AQUINO's Avatar
Default very high pitched noise from engine?
My car makes a very loud high high pitched whistling/squeeling noise....when i turn my AC on it goes away, and when i turn it off it takes a couple minuted but it slowly comes back. Also, when its cold out (52 to 54 degrees in the morning) it wont go away even if i turn the AC on, but it goes away when the car is warmed up and the AC still on.. Anyone have any idea what this could be??
Old Jan 14, 2007 | 07:41 PM
3.4camaro's Avatar
the AC has its own belt. that might be it, the ac belt.
check all your fluids before you buy anything first.
Old Jan 14, 2007 | 07:52 PM
2001NBMZ28's Avatar
Not the air pump is it?
Old Jan 14, 2007 | 09:24 PM
Alpha-Q's Avatar
It sounds a bit like the fan belt could be slipping. maybe.
Old Jan 14, 2007 | 09:27 PM
I wish i could get a vid up but unfortunatley my cars in storage rate now.....the car is usually fine in the summer if i have my AC on but it gets really bad in the spring and fall....and theres no way of getting rid of the noise until the car is fully warmed up...im sometimes embarrased to drive it
Old Jan 15, 2007 | 07:50 PM
any other ideas??
Old Jan 15, 2007 | 08:08 PM
2001NBMZ28's Avatar
Well, if you had the car - do a cold start and pull the AIR PUMP fuse under the hood to disable it - see if it goes off immediately. That would tell you if it was the pump. Might be a pully/tensioner too.
Old Jan 15, 2007 | 08:22 PM
APSS's Avatar
Try A New Belt. They Have Thier Own Personality. Like Women Quiet Now Loud And Obnoxios Later.
Old Jan 15, 2007 | 08:41 PM
Thanks for the info guys! i will be sure to try this soon!
Old Jan 31, 2007 | 02:02 AM
2000OnyxZ28's Avatar
it might be the ac compressor clutch
