o2 sensor ckt slow
right before i did the burnout i put it on a lift and used RTV gasket maker (hi temp) to seal up the connections between my Y pipe and the headers, as well as the joint in my 2piece Y pipe. sealed them up good and then put the stainless band clamps back over the joints reallly tight.
id say about 2:30 worth of tire shredding
till my tires were down to the threads...
abs light comes on and what not.. thats normal it does that at the drag strip sometimes
after about 20 miles im cruisn along (new tires of course) and my SES light pops on... wtf
go to advance.. code reader spits out 4 codes
1. p0133 02 sensor ckt slow bank 1 sensor 1
2. po153 02 sensor ckt slow bank 2 sensor 1
3. p0133 02 sensor ckt slow bank 1 sensor 1 (PENDING)
4. po153 02 sensor ckt slow bank 2 sensor 1 (PENDING)
what does this mean....
and how do i fix it?
should i just delete the codes using a reader thing and see if they come back or has my tire destruction caused some serious harm to my car?
narroband 02 has been stuck on yellow since then
even though its on the rear o2's that it reads off of
but yeah i killed the SES light and it came back 2 days later
