Sponsored by: CARiD
Powersteering whines in Cold Days
Old Feb 1, 2007 | 04:14 PM
DrivenWS6's Avatar
Default Powersteering whines in Cold Days
On some of the colder days like 40 degrees or lower my powersteering whines. Is that the rack causing that or is it the pump that is getting weak. I never lose powersteering I just cant stand the noise.
By the way if anyone knows of have a low mileage rack and pump I would be very interested in buying it.
Thanx ben
Old Feb 1, 2007 | 08:38 PM
ravensfan's Avatar
I noticed this the other day as well. Im curious as well....
bump
Old Feb 1, 2007 | 11:19 PM
staringback05's Avatar
its usually just the belt, its not a big deal...if its a continous thing, then id worry about it
Old Feb 2, 2007 | 10:49 PM
DrivenWS6's Avatar
I have a pretty new belt on mine. I am pretty sure its not the belt squealing. Its definately the pump whining just like if you have air in the system and stuff. I was just kind of wondering if its the rack going out or the pump gettin weak.
Old Feb 3, 2007 | 02:25 PM
is there any looseness when driving? and have you changed the pump fluid...you can see if theres any metal flakes from the rack in it when you do
Old Feb 3, 2007 | 02:39 PM
White_Ls1's Avatar
Speaking of that im replacing mine with synthetic this weekend.
Old Feb 5, 2007 | 01:27 PM
autotrix's Avatar
Closed ex-Sponsor Account
"Morning sickness" a common cold symptom for P/S systems.
A fresh fluid change can help, but often times the rack must be replaced
Old Feb 7, 2007 | 05:46 PM
01SSRMS's Avatar
I think you're on the right track with a change to synthetic. We sell a Power steering flush at work that does a pretty good job of it. It's basically a fluid change with some extra conditioners added. Does wonders on Ford and Dodge minivans that are notorious for the same symptoms.
Old Feb 7, 2007 | 07:39 PM
00WS6_TA's Avatar
I was having the same problem, last night i drove it fine, the pump just made noise until it got warm, after that no noise. Today i pulled it out of my garage and i have no power steering.
Old Feb 8, 2007 | 06:27 AM
BlackScreaminMachine's Avatar
Internet Mechanic
My DD, I put Lucas in the PS due to a leak, it thicker and actually gummed up the leak, during the summer its fine, if its below 32 degrees it whines like a bastard and it has hard to turn the wheel, the fluid isnt moving.
Every fbody ive seen has a issue with leakin out PS fluid, check it often, make sure it isnt low and whining on cold days shouldnt be a issue.
Old Feb 8, 2007 | 08:55 PM
DrivenWS6's Avatar
Yeah I have syntetic powersteering fluid and a Nichols teflon treatment in it. I have noticed that in the really cold days when i first start it up and if I turn the wheel its really stiff and has the typical "morning sickness" so I spose I will have to replace the rack and probably replace the pump also since crap from the rack may have gotten in it and dont feel like having to do it all over again in a few months cause the pump is out.
Do any of you guys know of a low mileage rack and pump for sale?
Old Feb 8, 2007 | 09:11 PM
2001 Pewter WS6's Avatar
Restricted User
I have a brand new Monte Carlo and it is doing the same thing. I took it into the dealer today and they added some fluid and it did quiet down a good bit. There was a lot of bubbles in the fluid as well. We will see how bad it whines in the morning, it will be like 3 degrees out...
