camaro foglight bulb replacement
Hey I am replaceing my foglihght bulbs in my 00 camaro and am wondering how i do this. Any input would be greatly appreciated. Thanks
Originally Posted by 98redM6
You have to push in on the bulb socket and twist at the same time. It won't be able to twist if you don't push in on the clip on the socket.
Originally Posted by EarlSS
Thanks for the reply.Whats the best and easiest way to get to the bulb socket...from under or can i reach it from up top. If from the bottom should i have to jack the car up. Thanks again
I pulled mine from the top last time. It took me about 30 seconds to take out, check the bulb number, and put back in. Just reach down there and you'll be able to get it. I've also done it from the bottom.
