Part number for fog light replcement?
Old 03-12-2007, 02:17 PM
iosigma's Avatar
Default Part number for fog light replcement?
Anyone know the part number to replace the the fog light bulb on my 2002 Z28. The passenger sdie went out last week. Also does anyone know how to replace the light in the passenger side door right above the handel? And even what type it is?
Thanks for any help!
Old 03-12-2007, 02:39 PM
mike s.'s Avatar
Call Autozone on those bulb #'s they have them both in stock. As for the inside door handle light, remove the phillips trim screw behind the handle inside the car, then remove the screw on the back under where the window and doorlock switch is. From there the plate will move enough to allow you access to the light fixture. The bulb socket should twist loose from the housing, and from there you simply pull the bulb straight from the socket. Give it a little wiggle before you tug, somtimes they are well stuck and they break in the socket, which is a pain in the ***. Also, dont rip the plate out after removing the screws, the door lock **** is fixed into the plate and it will tweak undesireably if you are careless, use finesse.
Hope that helps
Mike
