mid graqde gas.
and i only tear into people if they deserve it.
if you're going to bitch over the price of premium, sell your ******* car. it was DESIGNED to run on premium. the only reason why GM put the timing retard feature into the car is because they knew tightwads were going to bitch over the price of gas and use the improper fuel, costing them a lot in warranty repairs from damaged engines.
why would you buy a V8 performance car, then bitch about the cost of fuel and use the improper, performance and efficiency-robbing octane? i suggest you invest in a honda civic. you'd be better suited driving one if it's all you can afford.
if you dont understand the basic concept you honestly shouldnt be driving a car with a v8 in it......this goes for anyone
it's good you found this out. you could have been putting midgrade or less in your car, having less ping and not being able to hear it so you assume it's fine and run it for the longterm, then learn the hard way when your motor gets damaged. people put WAY TOO MUCH FAITH into the computer pulling timing. they think that because the computer pulls timing, the car is safe. it's just a precaution. it's not a fix that makes it as good for your car as premium. i'm glad you chimed in here.
that's exactly what it is. if you have access to premium, you should use premium. the car was made to run on premium. GM only says it's not necessary in order to increase sales as some people will just plain not buy premium. it makes no sense to buy a car designed to run on premium, then not put it in. you want to drive a camaro/firebird on reg/mid-grade, there's a V6 model. you want a V8? buy a mustang, they take regular.
JohnG
Its true around here the gas has gone down hill pretty bad. Shell is still doing it for me. I am not sure how i feel about this V power cleaning crap.
