Sponsored by: CARiD
Ebrake dash light
Old Mar 14, 2007 | 07:12 PM
lastcall190's Avatar
Default Ebrake dash light
...is not functioning properlly. Any idea what caused this? Ebrake still works, and I wouldn't care, but now to pop the drunk I have to shut the damn car off, then push the button, then start it back up. I know the light works because when I first turn the car on and I'm greeted with the damn lite brite show on my dash, the "BRAKE" one is lit.
-J
Old Mar 22, 2007 | 11:11 AM
xBROKEx's Avatar
sounds like the sensor on the ebrake might have come off or got broken. depending on weather or not it needs a ground to turn the dash light on there may be an easy fix by just unplugging the sensor and grounding the wire.
Old Mar 22, 2007 | 11:26 AM
jkichline's Avatar
You have to pull off the center console and inspect that e-brake switch. I'm 99% sure that your switch is not working properly. Once you see it, you'll understand.
Old Mar 22, 2007 | 12:41 PM
Great thanks! I'll check it out this weekend when I'm home!
-J
Old Mar 26, 2007 | 07:55 PM
I think it's loose... because now it's working, after idling a few minutes it will flicker... Exhaust hits the bottom of my car so that could probably be it. Thanks!
-J
