Sponsored by: CARiD
c5 parking break
Old Mar 28, 2007 | 07:27 AM
ls1builder's Avatar
Default c5 parking break
any way to adjust the parking brake in a c5 from the inside handle or is the only way to adjust at the wheel in the drum in hat if so how much drag should be on the rotor after adjusting??????
Old Mar 28, 2007 | 11:20 AM
Sneakyws6's Avatar
On the tree
If it is like the F-body setup the only adjustment is in the actual rotor area of the rear brakes.
you have to pull the rotor and the adjuster is on the bottom of the backing plate.
I adjust mine so that the parking brake holds when the handle is at 5 clicks. Do one side at a time until 5 clicks hold the rotor, then do the other side until 5 clicks hods that side and then put it all back together.
for some reason I have to adjust mine about once every 4 months or so.
Old Mar 28, 2007 | 06:29 PM
ls1builder's Avatar
i adjusted them at the rotor a while back but it sill only holds for a little bit keeps fading away i guess i'll just redo it again thanks for the advice.
