Sponsored by: CARiD
oil pressure???
Old Mar 30, 2007 | 01:35 AM
DMONEY06's Avatar
Default oil pressure???
alright i just changed my oil yesterday and when i went to cruise around the block it stayed consistantly above 40, then later on at night i stopped at a light and noticed that i dropped below 40 then when i gave it gas it would move up to 40 i used vr-1 sae 60 oil 6 quarts and there was no leaks tightend everything good is this something i should be worried about or nothing major???
Old Mar 30, 2007 | 03:16 AM
staringback05's Avatar
probably just the type of oil
Old Mar 30, 2007 | 04:50 AM
SStheBest's Avatar
how warm was ur engine when u changed it?...and 2 if u happen to be in ur LS1 most of the day ur oil pressure is gonna drop alittle...and 3 when u took from the light and it was barley over 40psi, look at ur rpms...its 10psi per 1000rpm...if ur managing to get that then ur fine...hell my car after 30min of drivin on a 80deg. day will idle around 37-40(and even lower if i have been racin) and go to 42-45 when i pull off.
Old Mar 30, 2007 | 05:28 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Why would you use this oil in an LS1?
Old Mar 30, 2007 | 08:43 AM
DMONEY06's Avatar
idk i just wanted to try it whats wrong with it??? the guy at autozone said it would be fine i checked the oil level this morning looked normal
Old Mar 30, 2007 | 08:44 AM
DMONEY06's Avatar
is it to thin or too thick?
Old Mar 30, 2007 | 08:45 AM
DMONEY06's Avatar
it was cold as ice it had been parked for 2 days i also changed the plugs to e3
diamonds!
Old Mar 30, 2007 | 09:21 AM
A-Dub's Avatar
The guy at Autozone is an idiot
Old Mar 30, 2007 | 10:29 AM
RPM WS6's Avatar
He told you to use a straight 60 weight?
Might as well pour gear lube in the motor.
Drain that stuff out and use a 0, 5, or 10 W30; or a 0 or 5 W40 of your choice.
Old Mar 30, 2007 | 11:52 AM
Sharpe's Avatar
Gods, man. 60 weight?! It really doesn't matter what you use ... unless you go crazy and put something like 60 weight in it. I mean, gee. It says 5w30 right on the oil cap. weren't you worried? Honestly, drain that!
Give the phone number of the AZ you went to and the name of the guy. Seriously, I want to call them just to ask what Kind of oil to use. Seriously.
Old Mar 30, 2007 | 10:32 PM
ghardester's Avatar
RPM WS6 is entirely right, and so is staringback05. So don't you boys get into another oil pissing match, ok?
Old Apr 2, 2007 | 05:43 PM
bigbadbowtie94's Avatar
SAE 60 thats crazy!!! I hate those guys at the parts counters that have not the slightest clue!!!! Not to bash.... but u did read the filler cap that clearly states 5-30? Yea u can change up a little but, 60 weight????
