Sponsored by: CARiD
clunk noise on drivers side shock
Old Apr 2, 2007 | 09:01 PM
fortmyerspolice's Avatar
Default clunk noise on drivers side shock
It started making this noise today, everytime I push down on that side it makes a clunk clunk clunk, what do you think its is?
Old Apr 2, 2007 | 09:34 PM
taintedmeat's Avatar
The shock itself, upper or lower balljoint, upper or lower control arm bushings, maybe even tierod end but probably not so much on up and down movement.
Old Apr 2, 2007 | 09:41 PM
03 BUSA's Avatar
Mine did that years ago. I found the shock top bolt/stud became loose. I would pull the interior panel off and retighten. It worked for me.
Old Apr 3, 2007 | 01:40 PM
my dad said its probably the balljoints, the car has 79400 miles on it. How can I really know what it is?
Old Apr 3, 2007 | 06:13 PM
Jack it up by the body jack points so the suspension is hanging freely on that side. Use a jackstand if you can. Use common sense, you can make the car fall on you if you do this halfassed.
Once you have it in the air, grab the front wheel on the side with the clunking and see how you can move it. Up and down, side to side. Look at how you're able to move it, and then while you're moving it, look at the suspension components nearby and see which one has the play in it. You should be able to see where the movement is coming from. If you move it around hard enough, you'll probably hear the clunking also. Left to right(front to back) movement is usually the tierod end, up and down movement is usually a balljoint, could possibly be control arm bushing also. A LITTLE play is ok and pretty normal on suspension components with some miles on them, but if it flops around something is busted.
If you don't think you can get the car up safely, just take it somewhere. Saving a couple hundred on a balljoint replacement isn't worth a crushed torso.
Old Apr 3, 2007 | 07:14 PM
waterbug1999's Avatar
Mine did that on the driver side front. When I lowered the car 1" I put new shocks on and the problem went away... So, I bet its your shock/strut.
Old Apr 3, 2007 | 07:28 PM
I'll try that tommorow, thanks. Btw how hard is it to change one of these if it is busted? My dad's bitching at me to take it to Pontiac, but who knows how much they'll charge.
Old Apr 3, 2007 | 07:41 PM
Tierod end is easy as long as you have a pickle fork. I've never tried a balljoint, but it looks like it could be a pita from what I've read.
Old Apr 3, 2007 | 09:04 PM
My dad said it could be dangerous if I leave it unnatended. Is this true? Something about the wheel ****** up?
Old Apr 3, 2007 | 09:35 PM
Well if it finally breaks apart while you're driving you could lose control. Would probably suck if you were on the highway when that happened.
Old Apr 3, 2007 | 09:36 PM
great
Old Apr 3, 2007 | 09:49 PM
great
Yeah, I mean that's worst case, but you probably should take care of it before too long.
Old Apr 4, 2007 | 08:13 PM
jimbo98z's Avatar
It's really hard to diagnose something like that. It could be any number of things as previously said. Don't go ordering shocks until you check everything out. Mine did that and it turned out to be the same thing 03 BUSA's did, but in the front.
