Sponsored by: CARiD
untrackable misfire!!
Old Apr 3, 2007 | 09:07 PM
squall01's Avatar
Question untrackable misfire!!
ok, i'm getting a p0300 code and a flashing SES light. we hooked my car up to my buddy's Digital Horsepower tuner (unlocked for his V6) to do some data capture. it would only let me monitor 6 cylinders, but i found that i'm getting about 200 misfires on cylinder 5 every 20 seconds or so. so, thinking i had found the source of the problem, i changed the plugs on that side and swapped the 1 and 5 coil packs. took it for a drive, NO CHANGE!! however, i did find that this is only happening in the 1200-1500 rpm range with a load on the engine (doesn't do it sitting still in neutral). above that, the misfire count went to zero. i need to get this fixed, it driving my crazy!! any help would be awesome. thanks in advance.
--Bill
Old Apr 3, 2007 | 11:02 PM
TheBlurLS1's Avatar
That's what she said...
Swap all the coils, check it, then swap the wiring harnesses and check it again. You may have a broken wire somewhere.
Old Apr 3, 2007 | 11:03 PM
nofearracing28's Avatar
Pull the valve covers and check the valve springs, rocker arms, ect ect.
Old Apr 4, 2007 | 01:42 AM
connexion2005's Avatar
or you can get a tethoscope or however you spell it and try to hold it to each primary off of the header...you will generally hear alot more noise coming from the missing cylinder do to just moving parts and no ignition...
Old Apr 4, 2007 | 06:08 AM
squall01's Avatar
the part the confuses me and makes me think it's sensor is the fact that it runs perfectly above that rpm range. i figured that ruled out mechanical failure in the valve train...i could be wrong though. so Blur, you think i should start with moving all the coils around and examining the the harness?
Old Apr 4, 2007 | 07:08 PM
squall01's Avatar
i was talking to some friends today...could a fuel injector be the problem?
Old Apr 4, 2007 | 08:30 PM
JL8Jeff's Avatar
Fuel injector, spark plug, spark plug wire, coil. Those are the starting places. Watch it run at night and see if there is a slight arcing around that cylinder.
Old Apr 4, 2007 | 10:18 PM
I've seen in other engines(5.3L)where a valve spring broke and the compression and leakdown test passed. Had a misfire below 1500 RPM and went away above that.
Old Apr 5, 2007 | 07:31 PM
squall01's Avatar
i'm gonna take it in to a GM service center and let them diagnose it with their big fancy schmancy computer. lol.
Old Apr 5, 2007 | 09:52 PM
Michael02hawk's Avatar
After a cam swap last year, I got the flashing SES light only during a certain RPM range just as you. Problem was, I needed to perform a CPK re-learn. Once that was done, my 'false' misfires went away!
Old Apr 8, 2007 | 03:08 PM
squall01's Avatar
only thing i wonder about that is the fact that my cam is still stock. is it common for them to lose the position of the crank?
Old Apr 8, 2007 | 06:42 PM
JFHAWK94's Avatar
+1 for the valve springs. I had the same problem in the same rpm range the car ran fine no noise. I pulled the valve covers and found the no 3 and no 7 exhaust springs broken.
Old Apr 9, 2007 | 05:54 PM
squall01's Avatar
so you had the flashing ses and the p0300? i just had the injectors cleaned at a dealership...still no change.
Old Apr 9, 2007 | 07:57 PM
wrencher's Avatar
wrencher
You need to monitor the misfire counter logs for all 8 cylinders.
The cam crank relationship is timed if ouyt of synch they set a seprate code.
If it is flashing it is a current trackable misfire, you should be able to look at the logs & narrow it down.
Old Apr 9, 2007 | 10:31 PM
JL8Jeff's Avatar
My 96 SS used to come up with the misfire which was always P0300 when I checked it after a while. I got a scanner and traced it to P0302 when it was actually occuring and then it changed to the P0300 which made it look like random misfire. I changed the plugs, wires, moved injectors around, did coil and ICM and never got rid of it. But even when it would pop up, the car was running smooth as glass so I think it was a false code. The guy I sold the car to still gets the code once in a while and he said the car never skips a beat so I think it's an ECU issue or maybe faulty wiring somewhere.
Old Apr 10, 2007 | 06:07 AM
squall01's Avatar
what is the best way to monitor the misfire logs? my friend's tuner only monitors 6 cylinders.
Old Apr 10, 2007 | 10:18 AM
squall01's Avatar
does anyone know if the computers read the cylinder numbers the same on the v6 and the v8. for example, cylinder 5 on a v6 is still the 3rd one back on the driver's side on the v8.
Old Apr 11, 2007 | 07:45 PM
squall01's Avatar
i'm thinking about checking the injector. what is the best way to do this? also, is there a way to tell if it's a valve spring without pulling the valve cover?
Old Apr 15, 2007 | 02:49 PM
squall01's Avatar
just figured i'd check back and see if anyone had any fresh ideas on this. i need to get this thing fixed!!
Old May 4, 2007 | 06:53 PM
squall01's Avatar
well...here is an update. so far, we have swapped the coils around, injectors, plugs, wires...everything...still cylinder five. the code is now actually showing p0305. so it's something wrong with that cylinder. what should be my next step? pull the valve covers?
