Sponsored by: CARiD
No power to diagnostic port?
Old Apr 12, 2007 | 05:56 PM
TheSecretFormula's Avatar
Default No power to diagnostic port?
Just went to Autozone to have them pull the codes on my car to see if I have anything other than the obvious rear 02 and EGR codes. Well there is no power to the diagnostic port. The guy said it runs on the same fuse as the lighter. Honestly I had no clue if the lighter worked or not. It does not. Which is the fuse for it and is it true the diagnostic port runs off of that fuse as well? Thanks.
Old Apr 12, 2007 | 06:06 PM
2001NBMZ28's Avatar
He is correct - check the "CIG/ACCY" fuse.
Old Apr 12, 2007 | 11:31 PM
96slow6's Avatar
Did you have the ignition on?
Old Apr 12, 2007 | 11:42 PM
BLKWS.6's Avatar
+1. It happened to me too. Don't sweat it, I forgot which fuse it was but it is the accy/cig lighter fuze. Replace it and you are good to go.
Old Apr 14, 2007 | 08:59 PM
qwkta98's Avatar
check wiring if probelm persists
Old Apr 15, 2007 | 03:50 PM
It was just the fuse. I changed it and all is well. Thanks.
